Hey,
Today i got my second a1 Mini. But the new mini is in idle so much louder than my mini from Late 2024. is this normal?
Thanks for your help.
Hey,
Hi, I bought an a1 mini a few days ago, also a late 2024 and it is not noisy. At rest it’s practically inaudible, when it has a heated nozzle it’s about 26 db, and during printing the readings ranged from 36 to 52 db on standard settings.
I’ve just received my A1 Mini yesterday, and i noticed 2 things:
I got my mini 1 week ago. Yes, that thing is loud. It’s not the movements of the axes it does, which are really very very quiet, but both the fans of the hotend and mainboard. I wonder too if that is normal and intended to be like that. I have to measure its loudness with my pretty accurate dB meter (Digital Sound 8922), but I really can’t imagine that is anywhere in the 30s or 40s region. I think it’s more like 60+ dB 1 meter away. I will post results.
I’ve just made a little test print and confirmed what you say, the two fans are very loud, and while the hotend one can be lowered, the mainboard one is constantly on and on a much higher level, being almost unbeareable standing near for long period…
Perhaps they had mainboard problems and since then raised the fan speed…Seems kind of a crude solution.
Yes, I agree. got two, one in late 2024 and one of beginning of 2024, the late model has a loud fan going when it’s sitting idle, I’m gonna open a support ticket now because that’s just unacceptable
I faced the same problem with the A1 printer. One was from 2024 and the new one from 2025. I immediately noticed a noise difference in the part cooling fan - about 10 dB louder. The old printer measured around 55 dB, while the new one hit 68 dB.
I started my investigation by disassembling the printer to check if they used a different fan model. It turned out both printers had exactly the same fan model and firmware. The only difference was that the fan on the old printer was full of dust.
After I cleaned it, the noise level went up to nearly the same as the new one (around 65–68 dB). Interestingly, once the dust was gone, the fan became too strong, so I reduced the max fan speed to 70%. That brought the noise back down to about 55 dB.
I find mine (new this month) incredibly quiet in contrast to the P1S it sits next to which makes its presence known.
However the little victory fanfare just made us all laugh with its sheer ridiculousness when we first heard it. Petition for customisable tunes - I want it to play the Final Fantasy victory thing when it finishes a print.
