Minimal footprint X2D
I’m thinking about ordering the X2D, but I have limited space at my current setup location. Right now, I have a P2S that fits there perfectly. The X2D is basically the same size, but it has the extruder for the second nozzle on the back, so it probably needs more space in depth.
So my question is: could someone please measure how much depth is needed to set up the X2D? If you place it right up against the wall, what is the minimum floor space required so that the front doesn’t stick out?
There’s not only extruder at the back but also external exhaust. This one needs some distance from the wall, for obvious reasons. Giving around 7-8 cm for that, you need around 51-52 cm of space. 52 cm will give you 1 cm margin from front edge so if you want to do it safe, target around 53-54 cm. Around 48 cm is IMO absolute minimum with fan at 2 cm to the wall but i don’t recommend that.
As Vulc said, I’d allow about 52mm (20”) minimum. It isn’t really the appendages on the back panel that limit the depth, but the routing of the PTFE tubing that needs to be considered. The X2D seems to be a little fussy with filament resistance in the tubing, so keeping the loops’ radii as large as possible with the factory lengths is important.
You also need to account for the “poop” chute on the back. I actually use an old tissue box, but you can also print something.
thanks @Vulc and @Loren42
Unfortunately, that’s exactly what I was afraid of.
My Workbench is 46cm in depth and the P2S needs around 43cm.
I was actually pretty happy when I saw that there was a new 256mm printer available, hoping it would fit in the same spot as my current one. But oh well, I guess I’ll just stick with the P2S for a while longer. There aren’t really many reasons to replace it anyway.
For reference, this information is provided on the product pages..
https://store.bambulab.com/products/x2d?from=navigation
The recommended space for the printer is also included.
I’m guessing the last number is height, but if the second number is 70 cm deep, that’s crazy.
Why can’t they just add w, d, & h to their dimensions like they do in the build volume so it is clear?
I agree. That’s why I asked here.
The 406 mm isn’t the whole story, and 700 mm is far too generous.
My shelf space is only 46 cm, and I wanted to know if there’s any chance at all of fitting it on there. I might be able to come up with another solution for the fan. But the printer and the extruder have to fit within the 46 cm.
Width
Depth
Height
W x D x H.
The convention of WxDxH should be assumed unless otherwise specified.
I just measured my X2D depth (with fan) at 44.5cm. That leaves a gap of 1.5cm from the wall. My paper napkin calculations say that you need at least 2cm to provide enough air flow.
In other words, if you could somehow squeeze 1cm (47cm) of depth you should be okay. You might be able to drop that to 46.5cm, but you are getting close to the limit in my book.
thanks again - with that I have all information I need.
For the fan I can imagine a kind of adapter to bring it to the side of the printer.
Lets see, I am still not sure if I should upgrade my P2S with the X2D.
It brings some benefits and I have enough bambu points to get it….
Can I just piggyback on this thread to ask at what distance from the front face the front feet (if it has any) are?
Or to ask another way, if one was to set up the machine such that from the front to the wall it’s in front of, the distance is 470mm as mentioned above, how deep the shelf would need to be such that it was securely sat on the shelf but with the machine overhanging?
The feets (all of them) are nearly at the borders of the X2D. May be there is a gap of 5 to 10 mm from the very outer of the border to the outer of the feet.
Please also keep in mind that the machine can shift slightly due to vibrations. It’s not a lot, but during a 24‑hour print - especially at higher speeds - it can add up to around 1 cm on regular surfaces that are not anti-slip.
Because of that, it’s not a good idea to place the printer’s feet right next to an edge. People often overlook the fact that printers do move a little while operating.
It’s best to place a sturdy, non-slip mat underneath to prevent it from sliding or shifting - get one that’s heat-resistant because there isn’t much difference in price anyway. :grin: :+1:
