Missing Infill tuning - multiply infill lines, walls, angles
I enjoy Bambu Studio, but used to Cura I miss some very usefull functions such as:
  • Infill Lines Multiplier
  • Infill Walls Multiplier
  • Infill Angles (changing every layer, according to a set of chosen angles)
I wonder if my thread was read and registered by anyone?
Am I the only one missing these features? Or is there a way to adjust the settings and I simply didn´t find them?
Same here, i would like to add additioal Infill Lines for certain parts. I can’t find it either.
Let´s give it a try again. Anybody with suggestions? Is there a possibility to add these features in Bambu or Orca?
I’m similarly interested in more granular control, and in my case specifically I’d like to see the following (which could enable some of what you’re asking for as well):
  1. Ability to assign more than one height range modifier, for different height ranges throughout a part.
    I frequently want to have a progressive increase in infill density toward major feature transitions, so going from 15% to 30% to 60% to provide a tighter spacing prior to doing shell layers/changing “parts” within the model, especially when using multiple colors/materials.
  2. Ability to assign a modifier to a single part, rather than the whole object.
    Often I want to do the above internal density changes (or other changes) only to one part of a multi-part model, not through the entire z-height range of the slice area. The workaround is to load a modifier that is a slight offset of the same shape as the sub-part, but that’s tricky compared to just using bounding primatives and an “applies to ___ parts” picker.
`Renewing Request for Infill Tuning in Bambu Slicer
I’ve been following this thread with great interest, and I’m joining others like arciarc, stefanetter, and Jonathan_K in expressing my keen interest in specific infill tuning features for Bambu Slicer, including:
Infill Angles (with layer-wise adjustments)
OrionLord Today's Date
I want to renew this request for infill tuning in Bambu Slicer. The addition of these features would enhance our ability to create more customized and robust prints. Like others here, I find myself missing the ability to multiply infill lines, walls, and to set various angles for each layer.
If anyone in the community has found a workaround or an alternative method to implement these functions within Bambu Slicer, please share your insights. It's clear that many of us would benefit greatly from these capabilities, and any guidance or suggestions would be highly appreciated.
Together, let's continue to explore and push the boundaries of what's possible with Bambu Slicer. Thank you all for keeping this conversation alive, and I hope we can find a solution soon!`
bump. More basic slicer features from 2017 deemed too complicated for bambu users and painstakingly gutted from the slicer. Really shows what bambu thinks of us.
Just adding that this is a really useful feature I would like adding to Bambu Studio - It miss this feature coming from Cura.
+1. I miss infill multiplier. No data but feel like the infill multiplier feature is a good way to add strength vs just increased density. Especially if you are aligning your infill pattern with the direction of stresses of the part.
Surprised it’s not already a feature. Thought I was just dumb and unable to find it
I want this, I need this. why is this not a thing already :face_with_spiral_eyes:
I found this digging for a solution in bambu studio.
youtu.be/9qb25Gi4Jv0?t=302
Ive tried to duplicate the settings but I dont think we have all the same options.
I am attempting to print a diffuser as clear as possible. The above solution sets the infill line direction essentially to parallel. I am not worried about strength so much as this would be 100% infill. Your suggestions above would help to accomplish this I think.
If its possible now that would be helpful if anyone knows of a solution.
Please add an infill line multiplier. This is also a great option for cosmetic designs where an infill pattern is desired for appearance, but one can choose the infill size by selecting density, but also maintain structural integrity of the matter by thickening it.
As Bambu Studio is based on Prusa Slicer, it is hard to believe this feature has been omitted, particularly as it does not seem to be difficult to implement.
Man it’s a pain this feature doesn’t exist in bambu slicer. I just made a cad model with an intersecting body to use as a modifier to make a hole with 0 top bottom and triangular infill to act as braces. It is faster to make braces this way in the slicer than in cad and also prints faster. But with infill line multiplier setting missing, all I can do is up the infill % to up the strength but it doesn’t give the wanted result at all. Infill line width setting also doesn’t do the job since it is capped by the nozzle size.
Please Bambu, bring this feature to your slicer. This makes modifiers relevant in so many of my design.
Bump again. With all the great features I am also surprised this doesn’t exist.
I am just learning Bambu Studio coming from Cura and I used the multiple infill walls all the time to add strength to my practical prints.
Same, I use this feature for strength and making hollow parts that have strong interior. It allows better flexibility
I’m also looking for these features, specifically the Infill Angles (changing line directions for each layer). Has there been any movement in adding this feature?
I’ve been using cura for years and the infill line multiplier is my go to setting when I want a strong but fast print I also have a project where is needed but I’m thinking of just using cura on my x1c or just get my old printer going again
if any one knows a way to get this setting please let me know
yes, I was shocked when I found out, there is no “infill line multiplier” in BambuLab Studio. It’s based on OrcaSlicer and I thought it’s a more advanced slice then the UltiMaker’s Cura. Was using that for my old Ender3 S1 for years and being able to double or triple (or really any number) the infill lines is a real smart idea. Especially with the “lightning” infill when printing with no bottom layers. Can’t even find a g-code command for it.
That’d be so cool to have this feature in the BambuLab Studio!
Other way around, OrcaSlicer was based on Studio, but they have been moving in different directions.
