I have a Carbon X1C. Does anyone know where it goes? .2mm hex 4mm or 5/32” long. I removed it at some point while I was having different types of issues with the printer. It would have come from inside the printer chamber because that’s the only area I have been working in. It seems to be functioning OK except for some clogging issues I have been experiencing that are related to the extruder/hotend/nozzle. Over and out.
There is an awful lot of these tiny screws in there…
Any memory of what particular parts you worked on or what you had to take off?
I bet it to hold some cover or such in place…
Working on and around extruder.
Looks like one of the screws that hold the pcb on the clear plastic piece of the filament runout sensor.
Barryg41, if I’m thinking those are both 1.5 hex key. Mine is 2.0. Thanks all the same!
