Model not searchable / indexing delay on MakerWorld?
Hi community,
I recently published some new 3D models on MakerWorld. However, I noticed that when searching for the exact titles or main keywords in the search bar, my new models do not show up in the results at all (though older models work fine).
It seems like an indexing delay or search queue issue for newer models. Has anyone else experienced similar search indexing lag recently? Is there a normal syncing timeframe or any workaround to refresh the index?
Thanks for your insights!
It’s happened with several of my recent models in a row—I can’t even find them myself when searching on the site, and they’re getting zero traffic. At first I thought it was just a typical indexing delay, but even models published several days ago still won’t show up in search. Pretty frustrating!
More information would be helpful to better understand the situation. However, if your MakerWorld username is OpusMark, I can find your models through the search function.
The reason you’re getting very little traffic is probably that you’re publishing fairly generic items, such as simple picture frames and lithophane stands. MakerWorld is already heavily saturated with these kinds of models.
By the time you published your picture frame, hundreds of other creators had already uploaded similar designs before and after you. As a result, it’s very difficult for new models in these categories to gain visibility unless they offer something unique or stand out in some way.
Another thing to consider is that you’re promoting your picture frames including lithophanes, but the lithophanes themselves are not included in the 3mf file. That’s pretty misleading. I have no idea if you forgot them, since you’re promoting them?
As I said, this only applies if your name here matches the one on MakerWorld and I’ve found the right profile.
Thanks for checking and for your honest feedback! I’m glad to know there is no issue with the search indexing. Regarding the lithophane photos: because these frames are designed to fit custom, personalized photos generated by users themselves via MakerLab, I originally only provided the frame and backlight components. So I only provided the frame and lighting components. But I completely agree that this might cause misunderstanding! So I have decided to upload the lithophane photo I generated as well.
In addition, I need to explain that regarding lithophane frames, although there are quite a few related models on the platform, I found that most models are based on an older LED panel design, with single functionality and significant room for improvement in user experience. The reason I re-developed this category is that I used a new generation of LED panel—a high-CRI LED panel made of aluminum. The color temperature uses a warm color, which differs from the flaw of old LED panels where the light turns pale; the warm color temperature makes the image color more realistic. In terms of assembly, I also upgraded it, adopting a hidden touch switch with adjustable brightness, quick photo replacement, and modular interchangeable frame panels, while making the structure more compact. Additionally, the aluminum panel has better heat dissipation and lower light decay than the old fiberglass panel.
When this series of products was developed, I was full of expectations, thinking everyone would definitely like it very much because I indeed solved many problems.
Of course, looking at it now, perhaps my estimate was overly optimistic.
I hope more makers who like lithophane photos can pay more attention to my models. Please give me more suggestions, and I will continuously improve these projects and keep updating and iterating.
Regardless, thank you very much! Thank you for the feedback you provided!
Based on the cover image, that message wasn’t obvious to me at all. Of course, my opinion alone isn’t a meaningful benchmark, but it’s still worth considering.
Think about it from the perspective of a potential user: how are they supposed to understand what you’re describing just from the cover image?
Most users don’t spend much time digging into the details before deciding whether to click, download, or move on. In many cases, the cover image is the only thing they look at. If the key point of your project isn’t immediately clear there, a lot of people may simply miss it altogether.
I have postet this model two days ago…
This model: IKEA Korken Customizable Jar Label (I cannot put link here… not sure why)
When I trying to search it, no luck… Typing exact name.. I also tryied search it as annonymous user. Other models are working fine…
Put the title in quotes
