Modifier ignored for outer wall speed / overhang slowdown, BS 2.08
Hi all,
I’m trying to stop Bambu Studio from slowing down the outer wall around a few small holes, without switching off overhang slowdown for the whole part. A modifier seems like the right tool, but it doesn’t change anything in the G-code.
Setup
  • Bambu Studio 02.08.02.61, H2S, 0.4 nozzle, 0.16 mm layers, classic wall generator, 2 walls
  • Part: box with a 2.5 mm vertical wall and horizontal Ø4 mm holes through the wall
  • Outer wall speed 200 mm/s; overhang speeds 60/30/10/10, overhang totally 10; “Smooth speed discontinuity area” on
What happens
In the upper half of each hole, the outer wall on the face slows from 200 mm/s down to 10 mm/s, ramping over about 5 mm on each side of the hole. This leaves a visible raised line next to the hole.
What I tried
  1. A cylinder modifier (Ø10 × 10 mm, axis through the wall) centred on one hole, with “Slow down for overhangs” switched off in the modifier. No change: that hole slows down exactly like the others.
  2. The same modifier enlarged to Ø20, so it covers the whole slowdown zone. No change.
  3. The same modifier with the outer wall speed forced to 100 mm/s. No change either.
  4. “Slow down for overhangs” off in the global process settings: this works. The face stays at 200 mm/s.
I checked the position in world coordinates and in the saved 3mf. The modifier sits exactly on the hole, and the setting is stored in it (enable_overhang_speed = 0).
Questions
  • Is it expected that a modifier can’t change outer-wall speeds or overhang slowdown, for example because walls are generated per object rather than per modifier region?
  • Is there another way to switch off overhang slowdown locally?
  • The “Detect overhang walls” option mentioned in older posts doesn’t show up in my version, even in Developer mode. Has it been removed or moved?
I can share the 3mf and the G-code.
Thanks!
In the slice preview, what line type is being assigned to those specific areas?
They’re assigned Outer wall, not Overhang wall (see image 3). In the upper half of each hole the outer wall drops from 200 to 10 mm/s and ramps back over ~5 mm on each side. Only a tiny segment where the hole closes is Overhang wall.
So the outer wall gets the overhang speed by overhang degree, and the modifier doesn’t change that. Only the global setting does.
