Varying print speed from fast to slow while approaching the outer wall would allow steeper overhangs to survive the first bridge. I have noticed that after the initial bridge layer, depending on how large the surface area is, the subsequent layers’ walls ripple out as they are already printing too fast. There is no way to configure bridges with multiple layers such as in Cura. This feature allows the slicer to use different settings for the second and third layers of a bridged feature. As for adding a minimum bridge length for supports, this would easily allow the slicer to ignore support placement for overhangs that are under a certain length. This would be most useful for keeping supports off of small screw holes that do not need to be supported. This is also a feature present in Cura. BS does have support x/y distance but this is not useful for this purpose as it adversely effects supports elsewhere on the model.
