Ai Mini.
At 90% the nozzle hits the print and fell on bed.
I’m using the texture plate, no glue. I need some help. Thanks
I didn’t have any problems, are you using the profile settings or your own…??
Can you send me the link you used please
The top 2 on this page:
Wireless Mouse 002
Bottom Shell v2.0
Top Shell v2.0
Thank You. It finally worked.
I have the same issue, 3 printed failures, the nozzle hots the tree support. I used my own print settings
Also 3 failures, tried on A1 and P1S. The failure is exactly at the same point every time. 74mm high, it over extrudes on the left side of the mouse, repeating the same line 4 or 5 times and then knocks it over. I have a video this time.
In fact, I can see in the Bambu Studio preview pane that it gets stuck repeating a section on layer 370 about 10 times. In the image below, that line that it’s showing that had just printed, it goes over this about 10 times causing too much extrusion in that point.
Try using the exact model I posted a few posts above.
The problem turned out to be a bug in Bambu Studio on the version I was on. It couldn’t handle small overhang walls and looped the Gcode. Printing again and it’s gone past that point now.
