Move parts freely on Z axis
Why do parts in Bambu Studio always HAVE to touch the base plate?
I’ve stumbled over this several times.
Example:
I wanted to print thin high parts.
Printing one part alone works. but as soon as I want to print more than one part on the board, they fall over.
the simple solution I know from other slicers.
I insert thin support parts that I position freely between the actual parts.
theoretically the function is available in the BS. (Add simple Parts) but you can not position the part freely on Z.
another example:
I cut a lying part vertically.
the cut is always recognized as under part.
If you then split the cut in the objects, these are then also moved back to the base surface.
very blod if you only want to remove one part and the rest should stay where it was.
Add a modifier to your object (as part of the object, right-click on the object in the object tab… man those are a lot of objects) and you can move it around freely.
Thanks for the answer.
I had also played around with this.
somehow I had to make the auxiliary part first to the modifier and then again to part so that the part is also printed. (in the slicer preview)
There still remains the problem with the vertical cuts.
This ought to be a FAQ. I now realise I have been giving slightly misleading advice in the past.
The slicer has the concept of objects consisting of one or more parts. An object is forced to sit with its lowest Z point on the build surface. The parts of an object can be positioned anywhere relative to each other. If you change the lowest Z point the whole object will drop to the build surface again.
The object view in the process tab lets you see the tree structure of objects and parts and lets you select them and change many process options for them.
In the prepare view left clicking selects the object. Alt Left clicking selects a part.
You have assemble and split commands to combine or separate objects.
You can add primitive shapes and file models to an object as parts or to the build surface as objects.
The cut tool has the option to cut an object into parts or separate objects.
You can change part types into normal (part), modifier, negative, and support block/add controls.
I have an example of a part I want to cut.
only the middle part/ the body should be removed. the wings should remain.
If I select the third option “cut into individual parts”, the parts remain in the right place for the time being, but I cannot split the cut into individual parts.
If I don’t choose this option, I can cut the section but the parts fall to the floor and have to be painstakingly put together manually.
this part is just an example and could be put on the back but it is the problem.
is there a trick i’m not seeing?
I don’t understand what you trying to achieve. I don’t understand what you mean by
the option is grayed out.
(the mouse finger points to the place)
The option is grayed out because the thing you selected is already a part, and you can’t split a part to parts.
I still don’t understand what you want. By “cut to parts” you CAN split an object into parts, and then you can select each individual part (click item in the object list, or alt+click on canvas), modify them, or even delete them.
The goal is to cut only the rear part of the dragonfly. The wings should stay where they are.
You can make cuts only on “planes” that in this case for the own you had to be sharpened 3 parts.
If you use the automatic option that splits the parts fall down.
This fall of the parts is the problem.
Hi there, I know you wrote this a while ago but…this just helped me but now how do I not print the cone? When I separate the items the item I needs goes back down to the grid.
Practical FAQ on how to move something on Z-axis based on my experience with some CAD/3D-print theory.
  1. When you import single STL/3MF file into Bambu Studio it brings it on a plate as a single Object. Objects always must be on the plate surface for first layer, or you must add supports, because you can’t print in the air.
  2. When you import two or more STL/3MF files in Bambu Studio it will ask if you want to put all files as Parts into single Object. Saying YES - you will get Parts that can move along Z-axis. Saying NO - you will get two separate Objects that can’t move across Z-axis.
  3. You can move Parts of the object on Z-axis freely, but if they will not touch each other on some layer and lowest part will not touch the plate - you will get an error highlighting that some Part is in the air and you need to add support.
  4. In a file tree in Bambu Studio we have following level structure:
    1. Plate (no matter how it is named, by default it’s Plate 1, but you can rename it)
    2. Object (no matter how it is named)
    3. Part (no matter how it is named)
  5. There are several scenarios of how to get all parts into single object:
    1. Select parts on plate or in a file tree, make right click and use Merge. Merge result in Object named Assembly, where all initial parts or bodies are Parts.
    2. Import two or more STL/3MF files in Bambu Studio, it will ask if you want to put all files as Parts into single Object. Say YES.
  6. STL/3MF files can contain several figures (solid bodies) inside. In this case first what you need to do - Split Object to Parts and then choose withing click on Plate or on file tree all resulted Parts and Object/Objects you want to combine in a single Object and use Merge command again. Important - Split in this case does not equal cut some Object. Split means disassembling Object container to individual Parts or Objects.
I hope it make sense and gives other people clarity of how 3D slicer from BambuLab works with Objects and Parts.
Very helpful. Thank you for this response.
