Moving the Print Head?
I feel like this is a very stupid question but I cannot find anything about it anywhere!
I need to unclog the nozzle but the print head is over the poop chute. I have repeatedly tried to use the app controls to move it but it does nothing. What am I missing?
I assume if I turn off the unit I can move it manually, but I need the nozzle hot to get the clog out.
Thanks for any help!
During print pause, you cant move the print head.
I had canceled the print but it was all still behaving as if it was paused.
I ended up turning it off and back on.
Then restart should do the trick.
Wish you happy printing! :slight_smile:
If you paused it and it parked over the chute, then you’ll have to cancel the print. If it still doesn’t move I would cut off and move manually to where you need it, then turn on and heat the nozzle from there. If the clog is in the nozzle and you have a heat gun you can use that to warm the filament. Don’t forget to check the extruder as well.
Thank you so much! I had to turn it off and on again.
