Multi-color support filaments
In Bambu Studio, there is an option to choose Support/raft base filament. It would be nice to have the ability to choose more filaments and let slicing algorithm to decide the optimal support for current layer to minimize material change.
E.g. on the ballerina model, there are layers, where only one filament color is used for model, but because of the supports of different filament color the tool have to change. It wastes time and material.
My idea is to select filaments [1] and [3] as possible support materials, and the slicer would create multi-color supports, where there the support layers at arm part would be from [1] Bambu PLA Basic white filament.
If you set support to virtual extruder 1 instead of 2 - I expect you will get a little bit of wasted changes at the bottom of the model - but not the ones doing the upper arm?
Also what happens if you set the support to ‘default’ rather than a specific virtual extruder?
Thank you!
I had selected one extruder before the first slicing and then checked the difference with the other one. Then the idea of selecting the optimal support filament for current layer came out. And it is already doing it as default. :smiley:
It is exactly what I wanted.
Would it be possible to provide more info on what you did to achieve this? I am trying to print a trophy and want it to be gold and the supports to be a different color(to save on using my gold). Before the supports reach the trophy I would like it to change back to gold so there are no markings from the other color. Thanks if you can help!
Hi there, I’m running into the same issue years later as you had with this pink and white model, where the first color is being used for all support regardless of changes further up the model. I’ve been 3D printing for over a decade and I cannot make heads or tails of what you and the other commenter are saying- “virtual extruder” doesn’t show up in any google search other than This actual post, can you elaborate what you did to get it to print like the photo above?
On the screenshots where it says 1 2 3 4 under filaments - they are the virtual extruders - they are not real separate extruders - but separate colours or filaments - sometimes using the same extruder and sometime different depending on the printer model.
