I’m having an issue where I want just the edge of a piece coloured as seen in the first pic. When I check out the preview, I can see that the colour goes deeper into the part then I want (pic 2) and you can actually see the dark colour infill through the finished piece. Is there any setting that I can change so it only prints a different colour in the area I’ve actually marked?
Not when painting, I think. If you can split off that edge into a separate object, which is then Assembled into the print, you can select only that object for the second color.
That worked perfect, thank you. Still super new to Bambu studio, but I right clicked on the object, selected Split Into Objects and it did exactly what I needed. Now only the edge prints in colour two. Thanks again ![]()
is it possible to print a colour .3mf file?
or do you have to add colours in the bambu studio?
