Hi there,
Is it possible to print multicolor (multimaterial) supports? My model is very complex so there are tons of supports, but the printed surface shall be as good as possible (and it would be very painfull to remove all the supports mechanical way, since they have to be really close to surface), so i bought BVOH to remove supports in water, but as i mentioned the supports have big volume and BVOH is quite expensive. I wonder if i can do like most of supports via one material and certain section underneath the printed surface from second material (this case BVOH)?
Thanks for any suggestions.
Studio allows the use of a different filament for support base and interface layers. It is all there in the profile support tab.
- Set BVOH for only support interface. That’s just a little touch
- For low price, for PLA use PETG as support interface, for PETG use PLA :> Works perfects, because the two do not stick to each other, only very slightly
