Multiple Excluded bed areas?
Can I somehow add multiple excluded bed areas? This would be great to exclude damaged parts of the printed and automatically have the Slicer avoid them when placing objects?
I am bumping this since you got no responses, I have the same question.
I just noticed that after switching to the Revo nozzle, since it’s much wider than the stock one, it slams into the aftermarket build plate alignment clip on the left side, when it’s going to the poop chute. I removed the clip for now, but would like to just exclude that little area of the build plate, but can’t figure out how, since there are already coordinates to exclude for the cutter.
Adding to the exclude area isn’t going to solve this issue. You will need to edit the machine gcode as these moves are hard coded into the slicer and not controlled by the exclude area.
Well that’s unfortunate, guess I need to learn Gcode.
