Hi folks,
It’ll be hard to give all the details as recommended as this has failed several times in several different ways so I don’t know if anyone can help, but I hope so.
I’ve been using the A1 Mini, Sunlu PLA+ white filament, using the bambu pla settings as i’d read that they are close enough to each other and usually get good results & on models printed from makerworld it has worked fine, but on my own I keep having issues.
The settings i’ve changed from default on my most recent attempt are;
quality;
Layer height - 0.1mm
Ironing type - top surfaces
only one wall on first layer
strength;
wall loops - 3
sparse infill pattern - adaptive cubic
speed;
initial layer - 35 mm/s
initial layer infill - 85mm/s
outer wall - 180 mm/s
Supports;
standard tree supports
others;
fuzzy skin - contour
point distance - 0.2 mm
thickness - 0.2mm
I’ve been trying to print what I thought was a very simple model for over a week now, i’ve had a couple of decent results but never 100% and i’d say i’ve had more total fails than completed prints.
This is the model pretty much as it should be;
The only issue I had there was bad overhang;
Which I tried several things to fix & now have much improved just by slightly changing the model so it’s not quite as steep an angle.
The most persistent problem i’ve had is this;
The model prints up to this height & then one of the wings/ arms comes loose of the support & the whole print is over. Weirdly this only seems to happen when I try printing without fuzzy skin, so far anyway. I’ve tried various things to fix this & finally moved the printer off my wobbly standing desk on to an mdf sheet on the floor which still didn’t work so I don’t think it’s a vibration problem.
Anyway I’ve now put in some supports built in to the model (thin rods from the legs & body to the wings) and i’m hoping that will fix that, not ideal though as it adds more cleanup. Unfortunately I don’t know if it has worked as I tried printing yesterday with fuzzy skin again & it worked almost all the way to the end before;
Some massive layer shift occurred & again ruined the whole thing.
I just don’t understand what could be happening. I’ve never had a fail with a makerworld model so it must be something with my model, but with so many different types of fails & some actual successes, it’s just really mind boggling & frustrating, it’s cool to print other peoples models but it’s not what I wanted the printer for so i’m pretty desperate to get some consistency here.
Anyway, sorry for the long ramble, hopefully someone can help, if you need more details please let me know
