Multiple Laser Fill Settings per Material
Is it possible to set up laser fill settings with multiple intensity and speeds so you can get some different depth (Color Shading) within Bambu suite. Maybe have 2 different laser fill settings for a specific material to get the results that are wanted. I does this when dealing with photos, but I want to be able to have these setting based on DXF geometry.
Example.
Laser Fill 1: 50% power slower speed
Laser Fill 2: 25% power faster speed.
I appreciate the help if anyone has any info on this. it seems you should be able to have control over this, but can’t seem to figure out how to do it.
I found where to do this, but have to manually do it per item under the prepare screen.
is there a way to assign these types of setting by Layer or Layer Color. would make it much more simple.
Is there a test file for laser fill, to generate a tile of all parameters in order to determine the most suitable for the material? This would be very helpful.
