Multiple top surface rendering
Hello all,
I don’t know if this request already exist, but it will be super cool to have a feature in Bambu Studio to have multiple top surface pattern on one object:
for example :
You can do it.
Use a modifier block. Select the part, right click, add modifier cube. Resize and position the cube to be only covering the very top top surface then go to object view, select the modifier block and set Rectilinear for the top surface.
This is with Hibert curve selected in ‘Global’ view which will get the first top surface.
Left: two primitives assembled into one, with different top surfaces set in Object settings.
Right: Fusion model, using a modifier to accomplish the same thing.
You can also achieve this with Height range Modifiers .
Ok, cool !! I need to play with the software more :slight_smile:
thanks
