My Experience with a P1S Mid-Print Unexpected Utility Power Loss
Just wanted to pop on here and share my experience that I had today when a storm rolled thru my area and caused a power loss mid-print. This information is being shared to potentially help anyone who is panicking after a power loss, or just genuinely curious what would happen.
Obviously, from the previous statement and the title, I had an experience with power loss while my P1S was printing, today. I was 10 hours in to a 12 hour print, when suddenly the power goes off for about 10 seconds. My UPS kicked in battery power for my PC, but my P1S is only on a surge protector power strip.
I don’t hook it up to the UPS because in the event of a power outage for extended periods the draw on the battery would be too much for too long, and it likely wouldn’t be supplied enough power for an extended duration to finish whatever it was printing anyways - They only run about 20-30 minutes with just a TV and PC connected.
When the power came back online it didn’t come back smoothly, and it was a sequence of on, off, on, off, on power cycles/flickers, instead of a steady roll-on. So, with my computer working fine, and my printer looking like everything was okay, I turned and saw the display was on and functional, as were all the internal lighting LED strips. So, I was like - Awesome, nothing dead, still working… Until I tried the control panel. Literally displaying some information but totally unresponsive. I pressed all the buttons and got no response from any of them. The screen just stayed as-it-was. I was heart-broken. I thought for-sure that I was going to have to be filing a claim or going after somebody for the cost of a new P1S or at least replacing a motherboard in the printer. I power cycled the unit, one flick of the main power switch, waited about 5 seconds, and powered it back on. When it came back online the display was completely blank, and the start-up process was taking extensively longer than it ever had, to come back up to the main screen and show a good ready status. I power cycled it a few more times. After had no effect, I just sat back and let it sit with the blank screen running. Meanwhile, since I was getting nothing from the on-printer display and nothing from my computer, since the network was still down, I grabbed my phone and opened the Bambu Handy app, and went to my printer. At first it showed “Idle” but after about 5 seconds it displayed an on-screen warning notification in the BH app that there was obviously a power interruption. The warning said, “There was an unfinished print job when the printer lost power. If the model is still adhered to the build plate, you can try resuming the print job.” I was happy that the nozzle hadn’t caused any damage and I hadn’t moved it in any way since the incident. The option to resume printing was selected AFTER I saw that the temperatures had risen back to my previously-selected operating temperatures. I’m not sure if that’s something you have to do, or if the P1S will do that for you, but it’s what I did, and it worked! It only took all-of 30 seconds to come back up to temp. The questions on everybody’s mind is probably this - Did it mess up the print? The power failure did impact my print, but it was able to recover with minimal issues. There was a slight line all the way around my print, from the area the nozzle was at pre-interruption. But, it did not cause any issues for me, as this was simply a piece of utility furniture, and not something I was going to sell, or give away to someone. Literally just a toilet paper box, so they are guaranteed to stay dry under my sink, lmao. But, yes, it did cause issue and was not perfect.
I went thru a power-failure and learned something about my printer! I knew it had power-interrupt protections, but I didnt know what to expect, or how they functioned. Glad I now know!
TLDR: Power went out. printer hooked up to UPS. Power flickered multiple times. Printer screen unresponsive. Printer power cycled. Screen appears blank now. Screen allowed to sit blank and boot. Screen and printer show no issues. Print resumed with minor cosmetic damage/single line.
(Video of unresponsive screen immediately after the power came back on, prior to any power cycling.)
Nozzle remains in-place after power failure. Nozzle was not moved prior to re-heat and resume button press.
After a few more lines were stacked you can clearly see a cosmetic defect.
Thanks for sharing.
I am glad also to read that the problem is solved and hope it never happens again.
Nevertheless, I would double-check to ensure all printer components are in mint condition. Since there is no rush, you can upload the logs to BambuLab support and ask for feedback if any component was affected by the power outage.
I had the same experience, blank screen after power back on. The SDCard became unreadable.
What voltage are you Operating 110/220v ??. The manual says its just 350W for 110V, and 1300W for 220V operation. I really don’t understand why such a large difference. I am talking about A1 series printer
The heat beds for the X1 series, the P1 series, and the A1 are a fixed resistance connected to line voltage, 110 or 220V.
Power is voltage squared divided by the resistance, so doubling the voltage increases power consumption four times (and greatly reduces the time to reach printing temperature).
The bed on the A1 mini does not use line voltage, so changing the voltage does not change power consumption.
Hey for anyone in this situation who still has the printer remain frozen after you press resume in the Bambu Handy App - recycle the power again, and if the screen on the device is still frozen, restart the Bambu handy app, wait for it to acknowledge the device, then press the camera play button. This seems to wake the device up and allows it to resume!
I too wanted to chime in with my situation and hopefully help someone else who might can benefit from my experience. This literally JUST happened last night (7/8/2025) / today (7/9/2025).
I was 2 hours in on a 4hr 45min job when a major storm came through and knocked out my power just after 7pm last night. When that happened, I immediately went and unplugged all my surge protector for my electronic devices as a safety measure for when the power (surge) comes back on. Fast forward to now, it is 11:15am and my power has now been on for 45 minutes.
I was worried with my low filament supply that I had lost all that time (and filament) and didn’t really was to start over since I would have to buy more to finish the print. With that, I started searching on my phone as to what I could possibly glean from others to anticipate what can happen with my P1S when power is restored.
So. Here is what I learned and actually did to save my print.
My P1S was purchased 3 months ago so, I’m guessing with how new it is, it already had the power loss recovery feature set. Which, I didn’t even know that was an option.
Anyway, after the power came back on, I plugged everything back in and started them up (NOTE: I never opened the enclosure or touched the printer at any time during the outage). Incidentally, the print head was still in the same position when it lost power like others have reported as well.
Now, on my laptop, Bambu Studio was still running and showed the ‘power loss’ message under the Device tab and asked if I wanted to continue. But, before I clicked to clear the message and resume, I manually turned the temps back on for the nozzle and the heat bed under the Device tab. I set it to 200 C for the nozzle and 50 C for the bed. I watched it reach the set temps and then hit resume. It started moving and went back to the home position to do a quick dump of the filament and then just picked right back up where it left off.
So far so good. Thankfully this is just a piece for my AMS riser drawer and isn’t needed for any major load bearing weight support.
Anyway, this is my two cents and experience and hope that someone else can benefit from what I did to ‘save’ my print job.
We recently had a power outage while I was printing. I was very suprised that I was able to resume printing after the power came back on just by selecting the ‘play’ button on the keypad. It did leave a small artifact similar to what was shown above but it was not an issue in this case.
thanks this helped me out alot i was freaking out until i came here to see what was the problem i also had a line i was so close to beig finished with a 8 hr job like 42 mins left :
Happy I could be of assistance, with my prior experience. :slight_smile:
that defect is normal, it happens to me every time
Clearly you didn’t even bother to read the first post, and just went photo browsing… Nobody asked if it was normal…
It very clearly says -
I.E. - The whole purpose of this post was to SHOW that it was a normal thing to have occur, and what the return-to-operations process was…
UPDATE: 15 minutes after I posted this, I checked the printer and noticed that there was warping on most of the flat pieces that I was printing. Even though I did not touch the print bed or the printed models, the power outage and cooling caused the prints to lose adhesion to the textured PEI plate I am using. I canceled the print. So, my method described below seemed to work, except for the warping. Oh well.
My current experience with a utility power outage mid-print: 2 hours into a 6 hour print. Winter storm is coming with high winds. Power goes out at 3:30 am. P1S is on battery UPS back-up and still printing. Assuming the worse, and that the power might be out for quite a while and the printer would burn through the battery back-up before completing the print, I paused the print from the printer control screen. Then:
  • WITH THE PRINT HEAD IN THE PARKED POSITION, turned off the UPS, while leaving the power switch on the P1S turned on.
  • The power was back on 2+ hours later, but I waited until morning, turned on computer and started Bambu Studio, while also having Bambu Handy running on my phone.
  • I turned on the UPS, which started up the P1S; the screen was initially blank, but resumed to normal (it seems like in the last few months it has been taking longer for the screen to start up than it used to when I first purchased the unit, but that is info for a different comment thread).
  • Bambu Handy stated that there was a power outage, and asked if I wanted to Resume the print.
  • Not knowing what would happen, I selected, Resume.
  • The Resume progress wheel spun until there was an error message stating that the print head malfunctioned and needed to be restarted, or the printer or print needed to be restarted.
  • Rather than doing that, I looked at Bambu Studio on the computer, which also had a message stating that the power was interrupted, and wanted to know if I wanted to Resume.
  • Since I didn’t know why the Handy app was saying there was a malfunction, but Studio was still giving me the option to Resume, and after reading some search results mentioning issues with resuming if the print bed had cooled, I decided to pre-heat the bed and nozzle to the correct printing temperatures.
  • With the nozzle and bed at the print temperatures, I selected Resume on Bambu Studio.
  • The printer immediately flushed the nozzle and then went right back to printing, at the spot where it was paused.
  • It is difficult to see if there are any noticeable layer lines, but since I am printing multiple flat pieces, with white filament, I think that everything is fine.
  • I also think that pausing the printer and letting the print head park in its standard position was a wise thing. It was as if I simply paused the print, and then later resumed, under normal conditions, which shouldn’t cause layer lines, if all goes well.
  • As I write this, the print is still going, but it looks like things are good with the print and printer.
  • I am glad that I decided to install a UPS (just two months ago), because it gave me the ability to Pause the print, and then turn off the UPS power, which negated the possible negative effects of a sudden, unexpected power outage with the print head engaged with the model. However, I would not rely on a UPS to continue to supply power to the printer for an extended time. Most UPSs have a limited battery run-time. My relatively new 650VA UPS would only last for about 10-15 minutes. Older UPSs would have less capacity/run-time. This gave me enough time time to do the above steps.
I’m more interested in what happened to the onboard screen that went blank… did it eventually regain fully functional abilities ? Was the App (Bambu handy) able to rectify the “dead/blank” onboard screen issue?
