My K-Cup Dispenser
For anyone interested, my k-cup dispenser is now on MakerWorld. I felt like the world needed yet another one to choose from :slight_smile:
I have moved your post into a different category as it is the correct one to promote your prints.
I do like them. Far more useful than the McDonald’s dispenser I designed for dips as part of my “pointless” drive.
I am hoping you are eager for any suggestions.
I would consider some formatting on your description page.
Medallion Procedure:
  1. Use a clear plastic produce container and scissors to make lenses from product boxes (see photo).
  2. Using an X-Acto knife, cut the labels off of the four used K-cups you intend to stock.
  3. Press the labels into the cups flattening them so you don’t see the puncture.
  4. Hold the lens template and material together and trim around them with scissors (one for each flavor).
  5. Press the lens into the medallion cup over the label.
  6. Press a retainer ring over the lens to hold it in.
  7. Attach the medallion to the tube with double-sided tape or hot glue.
I have also made some small grammatical changes (feel free to ignore them).
Anything shown in italics is an edit.
Thanks Malc. I knew I needed to clean it up.
I seem to have a problem with navigation. Where did you move my post from and where did you move it to? I thought I was being careful in putting it in the right place.
See the category “Other Topics” > “Share your prints” this is where you are now. You had assigned a general category.
I simply ‘moved’ your post into the correct category.
This isn’t a physical move from a to b, it is which category should it be in.
An example; if you had a P1S specific question, you would put it in the X1C category, right. I just ‘moved’ it to the correct category as this is the one designed to group all the bragging (allowed) into a single location.
You can click the category to see other people’s models.
