My X2D nozzles ooze a lot and create a lot of mess. This printer is brand new and i only have about 8 hours on it. It happens mainly because they don’t wipe themselves before and after nozzle offset calibration (the final step where they use the new calibration pad on the X2D that wasn’t present on the P2S). The calibration begins by them changing filament, wiping any leftover ooze and then continuing by cleaning themselves on the metal pad with the dots. But the nozzles won’t stop oozing, they continue to ooze as they calibrate offset which makes a mess and covers the calibration pad with filament, they don’t wipe either after this step and move on to printing immediately after. So any filament ooze that was smushed onto the nozzles in the calibration process would stay on the nozzles, as seen in the attached image. This becomes a problem when there’s so much filament that it gets dragged into print lines and ruins them. And that’s only the first issue i have been experiencing. There’s so much ooze sometimes that the wiping pad makes the filament strings fly off, it has landed on the XY axis rods before or even on the glass side panels. The whole wiping station is covered with pieces of filament like that. My country has recently been hit with a heat wave and my room can get as hot as 30 degrees Celsius with 70% humidity. These issues don’t really affect the print quality, but it just creates a lot of mess that i have to clean up.
I mainly print with elegoo PLA. On the spool it says that the temperature range is 190-230, and i run my prints at 210. Don’t know if that’s too hot considering the weather is horrible here at the time of posting this. But my bambu pla has the same problems.
Nozzle temperature isn’t affected by ambient temperature in this situation.
It sounds a lot like you have a humidity problem. Dry your filament, then feed it from either a well-dessiccated AMS or other drybox.
Moisture trapped in filament expands significantly when heated, so if it enters the hotend and sits there being heated, it will expand and push out filament.
Uncommanded extrusion is often a moisture problem first
You can remove some mystery [calibration procedure] by just letting the extruder work alone.
Walk up to your machine, load a filament, set the nozzle to 220 [or whatever] and extrude. When the gear stops moving, do a quick wipe of the nozzle with a cloth. Does more spaghetti keep coming out, like, a lot? Wet. If youre lucky you might even see puffs of steam.
But then how do i get rid of the moisture. I already dried my filament for about 12 hours at 45 degrees. Should i buy a dehumidifier to lower the humidity of my room? Because currently it’s about 65-70%
One more round in the hotbox IMO lol and make sure the environment it cools down in is very dry [a bag, still in the closed AMS, etc, ideally with some form of dessicant] or itll soak it back up right away.
If you have a scale that goes to 0.1g, you can weigh, then dry, then reweigh. At some point you’ll stop losing weight so fast and thats a good indicator it’s taken enough dry. [cardboard interferes slightly with the fidelity of this measurement, since it absorbs moisture too.]
Unfortunately this is a common misconception. Weight difference tells you very little about filament moisture unless you get a big number. That can tell you the drying method got moisture out but even then it doesn’t tell you if it’s “dry”. In the extreme, if you weigh a spool, just put it in a box for 24 hours, take it out and weigh it again, you should see no difference too even though no drying was performed at all.
The way to gauge filament dryness is using humidity. There is a relationship between humidity and moisture content. The archival and museum industries do it all the time. They use desiccants to both dry and wet and determine moisture content of silica gel using humidity in a closed environment.
Filament acts like a desiccant in this respect and even though we don’t know the actual moisture content, if we measure the humidity in a closed environment we get a reproducible handle on filament moisture. Put a spool of filament in a sealing polyethylene cereal box, or even a gallon ziplock bag, with a hygrometer and read the humidity when it stops changing. For my printer setup, over 25% RH and PLA starts having issues. Over 20% with PETG and it will have issues.
The humidity measurement test will also tell you if drying is effective, ineffective, or if it’s even needed.
Caveat is ziplock bags leak humidity. Over short times you’ll still get good numbers but leave it for a day or two and it could leak up.
the hygrometer inside the AMS tells me the humidity is 40%, i am guessing that’s a lot and probably the source of the oozing. When i dry the filament inside the AMS, it goes down to as low as 16%. But quickly jumps back up to a 30% once the drying procedure is finished. Should i print one of those desiccant holders and buy desiccant silica gel in bulk? My setup is very amateurish, i don’t know what to do about the humidity.
Relative humidity has a big dependence on temperature. Hotter air can hold more water so RH drops. When an empty dryer heats up it’s normal to see a humidity drop. When there is filament in it it’s another story depending on how wet the filament is. Depending on the dryer it can easily cause humidity to spike.
Dealing with high humidity is a big subject but understanding it pays huge dividends. There’s a lot of threads here about humidity, drying, and filament storage.
Basically you want to keep your filament dry once you dry it because it’s a bother but also because water can damage filament and even make it brittle. You also want to dry effectively from the get go.
I really do not think this is an issue caused by wet filament.
I am experiencing the exact same problem on every single print with a brand-new X2D. The filament spools I am using are practically new and are stored in sealed cereal containers with the humidity measured at around 20% and I’m exlusively printing with bambu PLA. Despite this, the issue happens consistently, and in some cases the nozzle offset calibration itself fails because too much molten filament has accumulated on the calibration board.
In my opinion, the real problem is the order in which the startup operations are executed.
Right before the print begins, the printer heats the nozzle to printing temperature. At that point, the filament already loaded inside the nozzle starts oozing. The printer then performs the nozzle offset calibration while the filament is still leaking out.
This causes molten filament to be deposited directly onto the calibration board. It is then dragged around by the nozzle, transferred onto the build plate, and sometimes accumulates around the nozzle itself. Immediately after the calibration, the printer starts printing without properly cleaning the nozzle first.
This appears to be a software and start G-code sequencing problem, not a filament humidity problem.
The correct sequence should be something like this:
Perform an active retraction and clean the nozzle before the nozzle offset calibration.
Run the nozzle offset calibration.
Wipe and clean the nozzle after calibration.
Only then begin the actual print.
Have you ever found a solution to this problem?
I believe this needs to be addressed by Bambu Lab through a firmware, Bambu Studio, or start G-code update, because the current sequence allows the nozzle to ooze directly onto the calibration board and then begins the print without a final cleaning step.
Since you say “practically new”, are you counting on new spools to be dry from the factory? They can be a wide range of moisture contents even in still sealed factory bags with a desiccant pack in there.
In the sealed cereal containers, do you have desiccant packs? If so and you’re still showing 20% RH, your filament may be fairly wet depending on if any desiccant is saturated at that humidity or not.
25% RH on the humidity test is my absolute limit with water effects showing up somewhere before then.
You’re still kind of close to the edge (at least for me) but might not be water.
I am facing the same problem, and I agrees that Bambu Lab should do a firmware update, especially the sequencing of the starting procedure for X2D. It gets worse with PETG filament. Drying the filament does little to solve the problem. Found online, the recommended way is to change the Machine end G-code. However, I would prefer Bambu Lab to update the firmware over, we messing around with the gcode.
It’s been a while, so I am coming back to this post with foggy memory. But the solution that somewhat fixed the issue for me was disabling the automatic nozzle offset calibration before every print. And every couple of weeks i run it without any filament loaded into the printer. The thing is that bambu does this test with the nozzles heated up due to the fact that metal expands from heat, so they can get the best result. And the unfortunate byproduct of doing it like this is the oozing. Obviously this isn’t attacking the root cause of the oozing itself. But it’s the best “temporary” fix as the messiest part of the calibration is this test. But until bambu fixes the calibration gcode, this will always happen.
Dry, dry, dry… You state some scary RH numbers. Do you live in Hawaii or on the coast somewhere? I would be investing in some dry storage if I had your numbers. In fact, I did, and have a 3 step procedure on the way to my printer.
Step one: I bought a dry cabinet which holds up to 40 spools at 25%. The idea is to not let the moisture get above that to start with.
Step two: A 4-spool drier box to drop the moisture more before putting my spools in my AMS2 Pro’s.
Step three: I carefully watch and maintain my AMS2’s between 10% and 20% RH. And maintain printed desiccant holders which I maintain weekly now based on the RH readers of my internal Humidity meters, and my P2S humidity reads. So I check the RH in my AMS2’s two different ways.
Man, for your RH, you are going to need some serious dehumidifying for your static filament supplies. If you hope to keep the moisture at bay. My RH hoovers in the 30-40% area, and I tend to err toward the dry side.
Thanks for reporting back. I too would have bet on moisture first, but with a reasonably new product, it stands to reason that minor errors (for example too long a filament insertion length during or prior to offset calibration) can have rather nasty consequences.
Hope your resolution helps others until the X2D machine start gcode and/or firmware have received a few updates.
