Mystery clog
So my prints were failing in the beginning which I initially thought was a nozzle clog. So after replacing the hotend I figured it was good to go. Nope. Problem still persists. Not sure where the clog could be if it isn’t in the hot end. Any help would be appreciated
Is it a clog? Is filament making it through at all?
Have you checked the extruder assembly?
I had a clogged extruder on mine out of the box, had to disassemble it and pull a bit of plastic from inside the assembly
smooth sailing since on it.
Turns out the filament I had was out of spec. There wasn’t a clog after all. Got a bad roll of coex and they sent me another. Diameter ranged from 1.2mm-1.9 which was causing my issue
1.2 to 1.9 mm? What a bad QC there…
