Need advice on filament material for purpose
Hello! I’m looking for a material that can withstand temperature 130 C without deformation and can be printed with Bambu X1 Carbon.
Final purpose is container for silica beads, that after use will be placed for regeneration into drying oven at 120-130 C / 248 - 266 F (as per instructions for silica beads) for > 2 hours or even overnight.
P.S. No, it is not to keep filament dry.
Hello,
for high temp resistance i use Polycarbonate.
But for drying silica beads its better to put them on a big surface instead of an container or something. Kitchen oven works fantastic.
Regards CleMans
Well, the container is intended to be used in laboratory at ambient temperature. It is regeneration that is the high-temperature demanding part. Opening and closing container is what we would like to avoid. Question of having large area (I guess) can be resolved in design of container itself.
Polycarbonate… I must have missed this material . Thank for hint. With Glass transition point of 147 C it should work.
Probably, this would work: POLYMAKER PC02001 or POLYMAKER 70258
