I don’t know how Bambu feels about it, but I’d like to delete that annoying purge line across the front of my build plate. I’d rather just use a couple of skirt passes instead. The purge line (or whatever it’s called) is hell to get off and I’m afraid I’ll damage my plate. I looked through the GCode but couldn’t find any mention of it. Any help will be appreciated.
Just uncheck flow dynamics calibration on the pop up box used to send the print to the printer.
It is not a purge line, it is calculating the pressure advance or K value
If I remember correctly the OP has a P series so that won’t apply.
It’s easy to find the prime line if you use the Gcode preview in Bambu studio.
It’s label “Nozzle Load Line” around line 584 on a P series IIRC
If you need more info about how to see the gcode preview check out this post.
Yes sir, I do have the P1. Can you be more specific about which lines to comment out? Is it only 584. I’ll go now and take a look as I wait for your response. Thank you. Never mind. Sorry. I was too quick on the draw and didn’t read the article you attached. I’m sure I’ll find it there.
