Need Help A1mini and Polymaker Dryer Combo
I am trying to help my daughter set-up her A1mini remotely because I live on the other side of the country and have no access to the machine (and no Bambu experience).
I bought her a Polymaker Dryer box because the machine will be located in a basement with higher humidity. I assume that she can take the PTFE tube that comes out of the print head and insert it into the fitting on the Polymaker and feed the mini directly from the box.
If there is anyone out there using this combo, could you verify that this would work or describe how you hooked-up the dryer box? If you wouldn’t mind posting a picture that would be even more helpful.
Thanks.
Don’t have your specific dryer, but as long as the dryer allows for the spool to rotate while its inside of it, you’re on the right track, it should work as you expect.
Make sure that there’s enough slack to move in all positions of the 256x256x256, or itll yank the dryer and knock it over lol
