Need Help on Rejected Etsy Takedown Request
tl;dr: I could use some help from anyone who has been successful in taking down 3d model listings of unauthorized sellers selling your models in Etsy.
Checking Etsy recently, I noticed that a certain seller MalcomPrintStuff is selling printed copies of my Minecraft-inspired kit cards.
While these models are not MW Exclusive, the license I provided is CC-BY-NC-ND hence, selling of either digital or physical copies of the model is not allowed.
So I went to Etsy’s Reporting Portal and did the following:
  1. Created an IP Owner record to which I put chiz_m as the IP Owner.
  1. Added IP records for each of my models with type set to other. I thought of choosing other since there’s no selection in Etsy for “3d models”. They have options for Copyright, Trademark and Patent and I thought my models don’t fit in any of those.
  1. Afterwards, I created reports adding the Etsy listings containing my models being sold in Etsy.
After doing all of these, I got the rejection letter from Etsy, without any explanation of what information that I could be missing in my claim. I provided my profile page in MW showing the same models with the same pictures and I’m not sure what other proof Etsy requires.
Note that this is the second time I got rejected. At this point, I’ve no clue what should I do or what I’m doing wrong in my request. Appreciate if anyone can share some best practices on how to get successful Etsy takedown requests.
This is a legal process, they are expect legal entities to be filing (your name or your corporation), not made up user names like chiz_m. That alone could have been the basis of the rejection.
You made a mistake in choosing other. It’s a copyright claim.
If you fail again after fixing those, trying sending them a DMCA claim via their registered agent.
I just looked at your items, another problem might be that Etsy is questioning if you are trying to assert rights on the Minecraft trademark (which you would not be authorized to do), or that you might be using that trademark without their permission. I’m not saying that should invalidate your claim (for all they know you have secured the use of the trademark by following this process) but it might be another factor.
Thanks for the advice.
I’m using name as chiz_m coz I feel that it has to match the profile page I’m providing as reference. I did provide my full name in my Etsy profile.
If I understand you correctly, are you saying I should change to IP category from “other” to copyright? That’s even though obviously, I don’t hold the copyright to Minecraft itself.
How do I send them a DMCA claim via their registered agent? Should I send the seller the DMCA claim instead? Although the seller has not responded to my message requesting taking down his/her listing prior to me reporting to Etsy.
It does not need to match.
Yes. There is some ambiguity as to whether copyright applies to 3d printed objects from a STL file but they aren’t going to chance it. So that ambiguity works in your favor. Note in claiming a copyright or license violation you must be absolutely certain that they didn’t obtain the file under a different license (was it ever available without NC?).
In this case it would likely be a trademark instead of copyright, but like I said for all they know you are authorized to use that trademark.
DMCA applies to etsy, not the seller. So you send it to etsy.
Note I’m not a lawyer and it isn’t my intention to be giving you legal advice.
Yup, pretty certain that I have never posted the model with a commercial license even before.
I followed your advice and changed the IPs from other to copyright. Provided my full name and made sure my address and contact number are correct.
I hope Etsy honors my takedown reports this time and not have to resort to an actual lawyer issuing the DMCA takedown.
Provide your real name and address. You have to choose copyright infringement. Looks like you got all the other basses covered. I had several denied as well until I figured out how to do it.
Good to hear you got your request approved!
I switched the IP type to copyright from other. Hopefully that should do it.
May I know though what you put in the url information for your item? Did you use your MW profile or the model page in MW? Or something else?
How about in the IP description field? Below is what I put:
For mine I used the model page. And in the IP description I said something similar to what you wrote. Once I got all the information right, they’ve approved it every time. I’ve had them pull my stuff off of maybe 40 Etsy stores in the last couple weeks.
This is what I did exactly and I provided screenshots of the design process as well and this is the email I got:
To say that I’m frustrated is an understatement. On the one hand I don’t understand why Etsy is set on aiding model theft but then I see that they are willing to support other creators claims and then it feels personal. Both not a really good feeling, all the while some sad little nothing of a person is still selling my design for profit. I’ve reported again and will share the source files but after that I’m out of ideas
100% this is based on them knowing full well no lawyer on earth is going to take a case of someone’s copyright infringement being copyright infringed, so they know there’s no teeth to the DMCA notice. If Microsoft sends them a DMCA they’ll pull it in a nanosecond, otherwise I doubt they’re going to do anything at all.
This is what my summary looked like when my claim was approved. I had two three other claims denied before it. As far as I can remember, selecting ‘copyright’ was the right thing to select.
Thanks for sharing! Good to hear Etsy still approves takedowns.
Success! Etsy approved my takedown notice! There’s hope folks!
Thanks everyone for your advice!
Can you tell me where I’m making a mistake? Etsy keeps rejecting my infringement reports. I’d really appreciate it if you could explain what information I’m missing or what I need to correct so my report can be accepted.
We don’t know what’s in your report, so it’s going to be hard to tell you what you’re doing wrong.
For anyone landing here with a rejected report, these are the fixes that got takedowns approved earlier in this thread:
  1. File under your legal name and real address, not a username.
  2. Choose Copyright as the type, not Other.
  3. Link the exact model page, with its publication date visible.
  4. In the description, name your licence (for example CC BY-NC-ND), state that you never granted a commercial licence, and paste the infringing listing URL.
  5. Keep proof you made it: CAD screenshots and dated files.
If Etsy rejects it again, post your report here with personal details removed. People can point to the missing piece.
I went thru this and eventually got some stuff taken down, but it doesn’t really matter if the people doing it have dozens of accounts and Etsy is way too slow to act. My original design was not even on the first result page anymore because the scammers were using a sort of similar model they stole from someone else, while taking my exact name and adding 2.0 to it and stealing all my listing copy.
Etsy refused to respond to my report that they were violating the terms of the model they stole cuz it wasn’t my model, and ever after the creator put in requests it took months and was ultimately pointless.
If you have a real serious product, get a trademark or patent on it. Otherwise, expect it to have a short to moderate lifespan before the scammer/spammers destroy the market for it.
