Looking at the P1S interface board
Does anyone know what kind of connectors these are? I am wondering as I seem to see a lot of people having issues with one the fan connector and well I ran into an issue last night with my front housing assembly where one side of the plastic clip on this plug seperated. So it doesn’t clip in like it should at this point, I can get it to stay in however it doesn’t function like it should. I am now forced to purchase another assembly (I am not positive when it broke or if it was like this from the start). I am questioning if this is also why a lot of people run into the fan speed is irregular message. If one part of the plastic clip was broken during initial assembly and they got it to attach and it works. As it will work, but if you bump it or don’t get it just right it will have this issue again.
I couldn’t figure out why that clip wasn’t staying in on that assembly once I popped that cover off to do a nozzle change to a 0.8mm well one side of that clip is missing the plastic component covers the pins to clip in and hold them in place on the female portion that is on the “extruder interface board”. The fan has the female side, with the extruder board having the male component. As you can see in this picture one side of the clip has the plastic on it the other side doesn’t.
