Need help with a design
Hello, I made a design in aspire and saved it as a .svg I am trying to make a two colored coaster out of it at 95mm round and 4mm thick, with the lettering and outside ring one color and the rest a different color. I thought I could just bring it in here as a svg and work on it, but don’t know what’s going on or how to do it. Is there a good video that will show me how to bring this design in or fix it to bring it in so I can make a coaster out of it. Or somewhere where I could pay someone to make it for me? Thanks
Hi, I’m trying to load a .svg and getting the error, the file does not contain any geometry data, can someone help me, what does that mean and how can I fix it. Thanks
Post makes no sense in this context so deleting. And I wasn’t aware svg files could be imported into Studio. So no sense keeping it.
Here is a tutorial for importing an SVG into Bambu Studio.
S(calable) V(ector) G(raphics) are graphics files as the name implies not 3d object files. You would have to use a CAD software to change them into a 3d model or use Prusa Slicer which can handle them natively.
Do you still need help with this? I load SVG files into Bambu Studio and Orca slicer all the time. The only time I ever have the issue you are having is if the SVG is now closed. For example, if the SVG is of just a simple circle. If there is a tiny gap in the line, it will do exactly what you are saying is happening. The shape needs to be complete and contained. If there is a gap, it can not close the geometry to extrude it into a shape that is usable.
So you should check in Aspire to see if you see any gaps in your file before you export it. If it looks good and still having the issue, let me know.
