Need help with Manual Filament swap (4-way splitter + non-transparent PTFE
"Hi everyone,
I’m currently building my own drybox setup. I have 2 meters of non-transparent PTFE tubing, 16 bearings, and PC4-M10 connectors. Everything is going well so far, but I’ve hit a roadblock with the filament loading process.
I’m using a P1S (no AMS) and I want to use a 4-way splitter. My main concern is how to manually load and unload the filament without opening the drybox every time. Since my PTFE tubes are not transparent, I can’t see the filament tip.
Should I cut the PTFE tube between the drybox and the splitter and leave about 2-3 cm of filament exposed to act as a ‘handle’? My concern with this is: will moisture enter the drybox through the open ends of the PTFE?
What is the best way to handle this manual swap without compromising the drybox’s humidity levels? I hope I explained my situation clearly. Any advice or model recommendations (like a manual access port) would be greatly appreciated!
Thanks in advance!"
Buy some transparent tubes, they aren’t very expensive.
I would have liked that too, but there are none left in the country. xD
This is exactly what I’m looking for, but it’s hard to find the material again.
And even though it’s transparent, I can’t move the filament back and forth.:smiling_face_with_tear:
