Need help with print quality
I have printed this fidget spinner file countless times and havent any issues. I cant decide if its a printer issue, a filament issue (it shouldnt be, it does the same thing across several spools of PLA and PETG), or a settings issue but that shouldnt be the case either since I havent changed any settings.
Basically the outer layer of the print is perfect, the outer layer of the two inner rings isnt perfect, but it has no effect on the performance (ie its not causing clearance issues). Unfortunately, while the rings turn if you force them to, they dont actually spin, not super fun for a fidget spinner.
I am hoping someone can print the file and tell me if they are having the same issues or if its just a me problem.
Fidget spinners DO NOT CHANGE!.3mf (526.8 KB)
