Need to change flow rate from 1.12 to 1.06 after the first layer
Hello All, I have a unique request/ question that I need help with. I own a manufacturing business and recently purchased the X1C for prototyping. what we make requires a quality control which brings me to the question. I have been unsuccessful in printing TPU, I am needing the first layer lines completely sealed. I was able to get the result but have a rob peter to pay Paul situation. The flow ratio was increased to 1.12, temp increased, and speed slowed.
Now After this first layer, I can set the temps and speed back to normal rates like 240 and 100mms but I cannot change the flow rate back down to 1.06. Does anyone know a way around this.
** I need to change the flow rate from 1.12 to 1.06 after the first layer.**
There’s a setting for that in the slicers.
Assuming it’s a multiplier for the normal flow rate, I think setting it to 1.057 would turn the 1.06 to 1.12 for the first layer only. And you have a similar setting for top surface if needed.
Hi, I know this may be a stupid question but which one of these options is the first layer option? I see one where it says top surface. I was thinking that would be the top of the model, but which one would be the first layer that would have to be change.
Welcome to the forum.
“Initial layer flow ratio” is for the first layer.
