Needs two AMS units to print using both nozzles
Hi All,
Doing a little research here. So, if I want to do a multicolor print on the H2D and take advantage of both nozzles (red in one nozzle, white in another, for example), I need two AMS units. Is that correct? Thanks!
You can have one AMS and one feeding from external spool or AMS HT.
You can use two external spools if you wish.
All external
  • Left: External
  • Right: External
One external
  • Left: External
  • Right: AMS/AMS HT
Both types of AMS
  • Left: AMS HT
  • Right: AMS
I am unsure if the left or right matters which thing you connect.
When reading AMS, this means either AMS or AMS Pro 2, it also means any number of daisy-chained AMS units up to a maximum of four.
They say you can have up to eight AMS HT units and any combination of up to four AMS/AMS Pro 2 units providing a maximum of 24 colours.
I would like to see how those get placed around the printer though.
I’m new to 3D printing and doing research before buying. I have question similar to this thread. If I wanted to ONLY use filaments from inside a single AMS-2-Pro connected to a H2D. If I load 4 different color filaments into the AMS-2-Pro can a use any and all of those color in either nozzle? Or can a single AMS-2-pro only feed one nozzle? Sorry if I’m kicking this dead horse one more time!
You can only use the colors from the AMS unit that is connected to either nozzle, not all the colors from one AMS unit across both nozzles
Thanks! I was thinking that was the case, but hoping it was not.
A single AMS can only feed one nozzle.
