Itās not very intuitive and I only realized this earlier today, but the profiles you pick in the Filament menu donāt determine if youāre using the AMS or not. The labels 1, 2, 3, 4 do not correspond to your AMS slots necessarily.
Probably best by showing an example of bothā¦
So here I have two filaments in my AMS, weāll skip over the actual AMS slots for now. In Studio I pick filament 1 to be Polymaker PA12-CF and filament 2 as the recommended support material PA12-CF Support. However, notice neither profile is selected from the AMS filament section, they are from my user presets. This is because the filaments have no RFID, so I had to manually select something when I physically put them in the AMS and loaded them. So they show up as available profiles under AMS filament, but Iāve already made my own custom profiles for them, so thatās what Iāll be using.
I tilted the model so it would need supports for this example and then slice it up
Now click print plate. Since my last print was not with the AMS, the box is unchecked my default. But you can see it shows us filament 1 and filament 2.
You may notice the label says PA-CF, well thatās because in Studio under filament settings, there is a base type for each profile, and mine is set to PA-CF
Now once you click Enable AMS, youāll see that AMS slots have been assigned to filament 1 and 2. Mine are correct in this case, because I did this earlier today.
To change the AMS slot that is used for either filament you need to click the little drop down menu below the filament type.
Once you click the drop down then your AMS filaments will open up. Youāll notice that slots A1 and A2 are greyed out, and thatās because they have PLA and PLA support. This is where the PA-CF comes into play that I set when I first physically loaded the filament into the AMS. The type set in the AMS needs to match the type in whatever Studio filament profile you are using.
Also notice that filament 1 is actually in AMS position A4, and filament 2 is in AMS position A3. This is why I said that your filaments in Studio donāt necessarily correspond to your AMS positions. They can, if thatās the way you set things up, but it doesnāt matter to the printer or Studio
Also thereās nothing stopping you from doing things like this, where I swapped the actual filaments selected. Iām not sure why you would ever do this in this case. But perhaps if you were printing a multi-color print and you decided to change a certain color last minute, you could do it in the print screen instead
Now if I want to use the external roll (nothing with the AMS has changed). I go back to my print and Iāll select TPU for example.
Slice it, print it and by default AMS is selected. If I unselect AMS, it will automatically use the external roll.
Hopefully this all makes sense and not too many typos, my ADD is bad sometimes lol.
