New Bambu Studio user Cura question
Hopefully a quick question in Cura, you have the feature on the bed that shows you by using a different colour that your model is not parallel to the bed.
For example you import a STL and it wasn’t correctly modelled in 3d software, Cura tries to lay it flat but its not possible and you can visually see this by looking under the bed and it will show you in a different colour the area where its not parallel and will require support material unless you lay it flat.
Is there a visual way to see this in the Bambu slicer? I realise I can just simply press the Auto Orient button but wondered about the visual reference at all ?
Thanks
Neil
Barcelona
Have you tried changing the sliced profile panel that shows how long everything takes to the others in the drop down?
You can see far more information that the default one presented.
No.I’l take a look
thanks a lot…
No, If you load a file in BS & push under the bed, you will see white line circling the part under the bed.
BS doesn’t show any info until it’s sliced.
