New printing problem - Can anyone help?
I’ve been using my X1C for 2+ years now and have never had a problem like this before. The 2 photos are from the same print, one is of the ‘front’ side of a rectangular box, the other is from the ‘back’ side of the same box. On the front of the box there are obvious layer lines and layer shifts. This problem Does Not Occur on the back of the box. Using Bambu PLA, 0.4mm nozzle, 0.2mm layer height, all other parameters are Bambu slicer defaults. I’ve tried different PLA filaments, different layer heights. I’ve adjusted the belt tension. Did not help. Anyone have an idea as to why the back prints correctly and the front looks like doodoo?
Its hard to tell in the photo. Is that bin larger on the top than the bottom. AND do you have “Order of walls” set to outer/inner. If so try printing with inner/outer. The printer, or the filament profile might be off a little and its printing that layer mostly in thin air.
The other thing to try is toggling from Classic and Arachne. On thin walls sometime Classic or Arachne create weird issues on the outer wall.
Thanks for the input. The bin is the same dimensions on top and bottom. Order of walls is inner/outer. I’ll try changing from Classic to Arachne.
Check the two nozzle retaining screws to make sure they are tight, and try to wiggle the nozzle to see if it has any movement in it.
If other files are printing well, the wall thickness on this bin could be the issue coupled with Classic or Arachne. The printer could be trying to print two walls and they are not touching in the center well with the wall generation.
If that’s the case and its not a loose screw or wet filament,
Possible solution.
  • Toggle from Classic to Arachne or vise versa
  • Change the actual wall thickness of the file, Slightly larger or smaller.
  • Disable Precise Wall setting
I had an issue before where I set the wall of cylinder to exactly the thickness of 2 walls and had quality issues. I forget if I made the wall a little thicker to force infill or thinner with Arachne to force the printer to solve the issues of laying two lines next to each other that have to be perfect thickness at all times.
Just in case: It may be worth verifying hot end heat control: Part cooling fan operating properly, thermal paste for thermocouple and heater not yet brittle…
