Newbie question on printer profiles in Bambu Studio
This Snow Globe model shows as a 10.1hr print in makerworld, but when I imported it into Bambu Studio and slice it (Without changing the profile, only the Printer to an X2D) it gives a total print time of almost 18hrs.
I assume the designer has an X1C, as the layer height dropdown states “*0.16mm high Quality @BBL X1C”
So I exported the STL, re-imported it into Bambu Studio and duplicated the slicer settings. its now "*0.16mm High Quality “BBL X2D” with a print time of 10.7hr’s.
Job done (I hope. Time will tell!)
So, it kind of makes sense that printing an an X2D using an X1C profile would have an impact, but my question is what exactly is going on to use up the additional 7hrs of print time?
In your print preview, select line type in the dropdown and it will give you a breakdown of how much time each line type takes - compare that against a sliced preview with the correct printer and you’ll see where the differences come in.
