NFC doesn't work
Hi
i tried changing spool, turn off and on again the a1 printer, but nothing.
The spools are not recognized on the ams light.
i need always to set them manually.
Bit of a silly question but you are using Bambu spools correct?
yes :slight_smile:
Í’m having the same problem, I’m using bambu lab spools but the AMS doesn’t detect them, already unplugged en plugged the cable in and out, restarted the A1… nothing
With the A1 ams Load the spool onto the holder then insert the filament. If you already have it loaded, then unwind the spool until the filament comes out, with the spool mounted, then re insert the filament into the ams feeder. It has to be mounted fully before the filament is fed in or it won’t read the tag.If you reset the machine and the filament is already loaded its not going to read the tags that way.
thanks for the hint, but it doesn’t work.
FWIW, I had the same issue with my A1 and AMS. Had 2 spools loaded, both not detected. Set them manually on the A1, then in BS. After, I didn’t pay much attention to it, but then noticed when adding the remaining 2 spools a few weeks later, it recognized both of them. Don’t really know what triggered it to work, but it just did. I know this isn’t much help, but thought I’d throw it out there. Maybe I did a FW update?
heppend to me something like that.
i changed spool with a new one, the AMS lite detected just fine.
then i changed it with an old one for a different print, it didn’t detected i needed to set it up manually.
then i changed back to the new spool but is stops detecting it…
this behavoir is on all 4 slots…
can it be a SW error that it misses detecting correctly the spools ?
Really silly question, but you know the RFID reading can be turned on and off in Bambu slicer? (Athough to be fair I don’t have an A-series so I don’t know if the A-series supports that)
Hi, yes there is a option, it is on, and when i turn on the option “Update on startup” in goes worse even the filament that it recognize it doesn’t. and then they don’t get recognized anymore :sleepy:
Screenshot 2024-02-18 222558
I have the same problem. Although my AMS only rejects reading the RFID tags of the two left bays. I tried several restarts und resets. Without any success.
Same problem, first spool i used it worked than nothing since. Quite annoying and i have been only using Bambu spools for this purpose… guess i should start using other companies filament if i am not going to get a benefit…
Make sure you only insert spools when the printer is idle. The AMS will not register new spools when a print is on going.
I do not have the insertion update option on my slicer. Is this only available with AMS or is it supposed to be with AMS Lite also?
It’s still in the latest version of the slicer.
In the “Device” tab
I can’t confirm if this is present for the AMS lite as I don’t have one.
Same issue as
I do have an AMS lite and it does appear to be missing?
I have an AMS Lite on my A1, and it’s not reading filament tags anymore. The firmware is up to date.
I’m having the same issue for months now. I unplugged everything for over a minute. Plugged in everything and it still does not read the bambu filament. I have all in bambu spools too. I’ve turned on the read on read on insert and startup. Firmware is all updated on both printer and AMS Lite.
