No access to MicroSD-Card
Would greatly Appreciate any ftp software names that you are currently using and have found success in this option.
I’m using Total Commander for that
Come on Bambu…this is a very basic function that should be included in a $800+ 3D printer.
This error confused me as well. Thanks for the info. The good news is that you can still send the logs on the SD card to tech support via Bambu Handy.
Lucky you having a P1 or X1 - having an A1 without the capability to erase old prototype files is a big “no-go” for my daily printer work doing samples and many variants of a model…
And since Bambu Studio does not offer any support on this I’m not sure whether to keep the printer or not… no matter how fast or “good” (well, another topic)
Your correct, though the message could be a little cleaner. The first statement “Initialization failed”, implies an error. Something simple “This feature is not supported on the current printer”, maybe a little less bothersome or what would be even nicer is if they used a variable and replaced the ‘current printer’ with the name of the actual printer connected.
Thank’s to Bambulab they integrated the SD Card handling of the P1x to bambulab Studio in the latest printer firmware version. Unfortunately it work’s only in the web-Mode of the Printer. In the lan-only mode it still don’t work.
Thank you for this! I was trying so hard to get an SD card to work, just so I could make timelapse videos for my son, and this comment right here saved the day. I spent over an hour banging my head trying to get this to work, and I finally found your comment! I appreciate you!
Hi Frank, I got this working just this morning myself.
I recommend a program such as Cyberduck or Filezilla, but there’s lots of options available. With one of those installed, you’ll need some information from the WLAN Settings screen on the printer: the IP address of your printer on the network, and what they call your “Access Code”
From there, you’re all set! Open your connection settings and enter the following:
protocol: FTP
host:
encryption: Require implicit FTP over TLS
username: bblp
password: your access code from the wlan screen
The first time you connect, you’ll get an SSH handshake warning. Accept that, and you’re in with remote network access to your sd card over an encrypted connection.
Good luck!!
