For some reason there are no PA profiles or K values for filaments in my printer or in Bambu studio.
Also, I am missing the Auto Flow calibration button in the Calibration tab
Any idea what is going on with my A1 Mini?
Hi, don’t know about PA et K factor but the calibration option seems to appear in the print screen. It appears that the latest firmware is running calibration for an unnecessary long time so I would recommend you only do it for your first print when you switch the spool.
PA wouldn’t be ideal on an open frame printer, so I can understand if there are no profiles. However, I will suggest you make sure “Generic PA” is selected in the selectable filaments page, seen below. NOTE: This page is SUPER laggy to load up, be patient.
As for the lack of the K factors, I’m not sure why this changed, but they disappeared from that area of the slicer through an update a little while ago. But I think it still saves when you do the calibration, but I can confirm because I don’t use that figure.
Oh… sorry. I didn’t realize you meant Pressure Advance and not Polyamide. Disregard the screen shot section. But I still think the calibration tools will update the profile even if it doesn’t display after. But again, that’s from what others say, because I don’t deal with spending the time to tune it.
