No Sparse layers
I loved this feature when using PrusaSlicer. Any chance we could see this in a future update? Really does save on filament.
I also liked it - but I guess if they did implement it you would have to be careful to avoid the printed model being raised up too high - especially if you have the glass lid on.
I guess on the BL the purge towers are a little bit smaller than MMU2 due to most of the purge being off the bed.
The p2pp post processing software for prusaslicer/palette has the ability to replace a standard mmu2 purge tower with its own sparce version for the palette, so I guess it would be possible to adapt it, or write a custom script to strip out the ‘non purging’ layers from models that are small enough to work with a sparce purge tower.
Not sure whether Bambu slicer has left in the ability to run post processing scripts, will investigate.
