I recently also had this, and likely found the same resources (or lack of). The Chinese Wiki does at least list the error code. I swapped in/out 3 complete prebuilt hotends and saw the same behaviour. Day job is a precision microelectromech tech/designer/bodger. Owner & maintainer of many older & cheaper printers.
Short version:
- P1P (with 1-off AMS) long out out of warranty, didn’t care to wait for slow response to a ticket.
- Bought & installed a new TH board.
- New board gave same faulty behaviour. Multiple power cycles and factory reset & rebinding still gives same error.
What randomly fixed it for me:
With the AMS powered up, removing the PTFE feed tube from the top of the toolhead assembly and loading in a filament offcut manually via the P1P screen. Forcing the use of an ‘external spool’ from within Orcaslicer to run a test print then seemed to have reset whatever caused this. 5 or so perfect prints now (fed as usual from the AMS).
My shorthand notes on the error behaviour are below, if of any help or interest. Watching indicated temps rapidly rise (as expected) during load and priming but subsequently being reported by P1P screen and slicer as falling slowly by ~100degC before the print started, while molten smoking plastic dripped from the nozzle was …interesting.
HMS_0300_0200_0001_0003 reported by Android Handy app, 0300 8008 reported by Bambu slicer.
Power cycling allows manual feeding/loading of filament, hotend shows expected heating behaviour (above 200).
Then starting a print job causes the increasing temp to slow around 170, then slowy drop. Errors then reported by slicer and handy app, hotend temp automatically set to 90 until job is cancelled.
I have tried 3 different pre-assembled hotends. Connectors are undamaged and seat fine.
The TH board, the Extruder Connection board, and the TH board FPC cable all look ok, FPC cable seated correctly at both ends.
Sat 11/05
Installed new board.
Full recalibration.
Raised h/e temp to 230 via Orcaslicer.
Cooled/homed.
Loaded calibration model, fed filament from AMS, temp error "Printing Stopped because nozzle temperature problem.[0300 8008 19:35:43]. Temp dropped to 90. from ???/220.
Cleared errors via Orca, resumed. Temp slowly inc. to 194, then reset to 90 and cooled.
No error in Orca. Resumed, increased up to 185, then reset to 90. No error in Orca.
Cancelled print in Orca.
Loaded from AMS in Orca. Temp slowly inc to 155/250, then started dropping to ~110 while STILL POWERED.
Turned printer off.
Factory reset.
Rebound.
O/S; load from AMS rapidly up to 205/250 then slowly dropping while still appearing powered (orange icon in O/S). No error msg.
Powered off at ~150/250.
Back on. Shuffled AMS/1 & 2. Waited until all read.
Loaded PLA Matte from AMS/3. Temp to 250. Reached ~195/250 then temps slowly dropping while powered. No error msg. Powered off.
Back on. Unplugged AMS feed tube.
Homed. Manual temp on unit to 220. Bypassed tube and loaded filament, printed ok without using AMS. AMS on and connected.
Loaded Very Tiny Formula 1 Race Car. Printed ok as above with bypassed AMS. AMS on and connected.
