I think theres some general USB / SD Card bugs going around. I havent even updated my P1P or my Bambu Studio to the newer firmware/versions and every so often I get a random notification in Bambu Handy that my SD Card isnt good enough (its the original that cam with the printer). Almost feels like they pushed that notification to get people to update the firmware or something lol, not sure why im all of a sudden getting it when I did aboslutely no updating.
I had similar problems, it was because auto recording is enabled by default which will fill your flash drive in a few days, after disabling it, no more problems
Not a bad idea to leave it on, but you will need to delete files often. I like it on because if I miss a fail I can go back and look at it and then make the necessary changes.
But if you print from the card often, un-checking it make sense. I tend to format the card when it gets low, and that wouldn’t make sense if I wanted to print things over and over again from the card.
I guess the best of both worlds would be a logic to auto delete the oldest files for space, but that may be a little bit of a stretch to expect.
Does it really need formatting periodically? I was sure it just overwrote old files.
Mine hasn’t been formatted in almost a month and my ipcam folder is 82GB (out of 128 GB total capacity). Those 82 GB only span recordings for the most recent 26 (ish) hours of printing. All within the last 5 days.
I haven’t disabled recording or changed any settings. Seems like it must be removing old video files to keep the used percentage around 65%.
Since I had this enabled the whole time it at least did not work for me. I now checked the stick in windows. Also only 32GB used of 256. those 32GB are just Ipcam files
I have quite a lot of models, but nowhere near that many, and have deleted all the timelapse movies on the USB stick - yet it’s still mostly full.
The log files after each print are about 500mb; I suspect that the machine is creating one after every print, and that’s what’s filling up my USB drive.
