Today, my X1C formed a clog inside the extruder. It was not the first time. As far as I understand, it comes from high temperatures inside the chamber.
It is not a significant issue as I removed clogs successfully before by removing and opening the extruder.
The problem is that today after I removed the clog I still cant extrude… I even reopened the extruder in the unlikely event a new clog had formed but nope, no clog, the filament path is clear…
This is what happens when I try to extrude PLA with the nozzle at 260… what may be happening? Any ideas?
Does the extruder wheel rotate freely if you order it to retract?
If so, it seems you still have a clog. From the video, it looks like you still have a clog.
If you checked the plugs, as @R3d-Five mentioned, either replace the hotend or verify if the installed one has a clear path.
