Not on WiFi, how do I resume a print after runout or clog?
I have a P1S with an AMS. Due to my job, I am not able to connect via WiFi. Is there a way to resume a print after a material runout or a clogged printhead? When I try to unload material, it says ‘Printer Busy’ & won’t let me do anything. This is very annoying.
Welcome to the forum.
Connection to wifi shouldn’t matter as everything is done at the printer.
In the case of material runout, the printer will pause, you load the AMS with a new spool and then use the buttons to select and click play/resume. The printer will handle the rest.
There normally shouldn’t ever be a time you need to “unload” the filament during a job. With the printer paused you can manually activate the filament cutter and pull the filament back if this for some reason needs to be done.
