I’ve only had my P3C for a couple days so it’s still quite new but ive been using the yolo chords calibration for my filaments and have been getting significantly lower flow ratios than my other bambu printers compared to the default profiles. Specifically the Polymaker panchroma line, though similar for the bambu basic PLA. Anyone else having a similar experience? Bit of a pain to not be able to trust the generic profiles without a lot of extra blobs and scraping.
If YOLO Chords keeps giving you the same lower ratio on the P3C, I’d trust that number on this machine rather than the generic profile. Blobs and scraping with the defaults usually just mean the stock flow is a bit high for this hotend. Double-check that the profile is set to the right filament diameter and nozzle size, especially if this P3C is on a 1.75 or 2.85 print tool that doesn’t match your other printers. Once those match, use the calibrated ratio and ignore the default.
/Nils
