I just went back to the previous version. I did reload the latest firmware however yesterday, recalibrated the filiament and everything is running fine again.
OK,
So I have the same problems and more. The new version is also too liberal with files. It has deleted versions of the file I have created for backup because I was experiencing problems with files going away. It turns out that it is this new versions. In addition, you have to be very careful to save files in a different directory because any changes you can generate by mistake will go into the file you are working on. For example, after working for hours in painting your object, it is very easy for BS to change back to the object with no paint, and guess what? If you guess that you lost all your work you are right.
I have also found out that many of the parameters donāt do anything after you change them. I wonder if BS was developed correctly as it seems the UI is a copy from an open source program.
I donāt think the developers have learned to create a temporary directory for working in files, do all the work in the temporary file, then allow you to save the changes. Also, I may add, it should ask to to save your work before you exit. These are SIMPLE elementary workflows that every developer learns.
The Paint feature also, sorry to say, sucks. The blocker fails to block when you click on the mouse and when you try to drag to block accross it treats it as moving the object.
I also tried the Add Negative Part and it does not work at all. l
I have had the system for only three weeks and I have had nothing but problems with the darn system. Last night, after having an object printing during the day and during the night, I wake up to find blocks of poop inside the extruder chute and in the nozzle which damaged the print. Not to say, it ignore all the blockers and it was building trees inside the object which it was not supposed to do because it was enclosed.
Most likely I will cancel the purchase this week before I ran out of time. The other things I have done several of these posts on the hopes that someone from Bambu Labs will respond. However, I think that is wishful thinking. I will not recommend this company or their systems if I have to do that last drastic option.
BTW, I have fixed many problems, which required system work. I donāt think you should do that in a new system.
damn, was hoping for something I havenāt tried yet.
Currently sitting with a brick.
Iāve tried going back a version, then back 2, back to current, factory resetting after a downgrade, not factory resetting, nothing works. Iām not sure what else to do. was working flawlessly until June 5, then nothing.
I have same issue ⦠Not able to pass the pre-heating 0% stuck.
Good morning, my friend. I put off updating for a long time, but in the end I updated to version 01.09.01.00 in July and the same thing you mentioned happened. Just adhesion problems. Since your problem was a few months ago, could you tell me how you solved it? Thank you very much.
Latest firmware here and nothing sticks, changed the build plate, cool plate, engineering plate, pei plate and supertack bad adhesion issues.
