Oh wow! Thanks! Spent half an hour struggling with the clip, just to have it snap in place the moment it hit 160c.
Please note that the clip seems to be closed incorrectly and this can lead to problems.
The wire latch has two small sections that go in the middle.
This video should help you re-install the nozzle correctly:
Thanks for the note. Also the customer service from my ticket said my latch is closed in correctly.
In your video, you push the latch with 1 finger and closes. In all of my 3 previous heating assemblies, this was the case.
I wish I could post the video of how I mangled the latch I got with this defective heating assembly. I had to muscle it into its place witch great force using pliers.
The way I closed it first was how I thought it would close. Looking at his photo, I squeezed it in the middle and flow control is achieved, but I would have liked to have the heating assembly I got replaced as it is defective at the latch area.
You just made every person that read this wince. When you work on a 3D printer PLEASE treat it like you’re working on a delicate piece of electronics and not a forklift. If you ever need great force using pliers, stop and start over because something is wrong, very very wrong. Sorry, didn’t mean to get preachy.
Apparently I am not getting the right support that I had to repeat. Like many others who have continuous problems because of defective latches.
Yet I still am not getting the adequate support.
Keep preaching.
preheating worked for me - got to about 60c and it closed… Thank you!
I do hope you figured out why you were having trouble with the nozzle clip spring buckle not shutting. I had a bit of difficulty when I first tried it and found tiny bits of plastic stuck on the magnet side which pushed the nozzle out to where the spring buckle would not close. The pieces do not have to be very big to cause this issue. In fact, I had to use a very sharp pick to get the pieces out of the buckle itself. Once I got it cleaned, voila, it snapped in properly.
I have changed from .4 nozzle to .2 nozzle pretty regularly and have had the issue several times. Now I just make it a habbit to clean all the parts well before reassembly.
Good luck with that.
