Nozzle clumping error
During printing the A1 will seemingly randomly stop printing with the error Nozzle Covered in filament.
After checking the nozzle, and seing that it is clean i hit start again and it start printing again with no problem. I have turned off the option of the nozzle clumping in setting and the machine continues having this issue.
Have you verified that the build plate is not hanging over the heat bed just a little? that is usually the issue every time I get that error. Or there really is a clump. It is the build plate position check function and you can not turn it off.
I will check that thank you
