Nozzle Hitting the Print During Printing
Hi everyone,
I’m having an issue with my 3D printer. While printing a model, the nozzle sometimes hits or scrapes over certain parts of the print. This happens intermittently during the print process.
Before starting the print, I made sure to calibrate the bed and the Z-offset properly. I also performed routine maintenance, including lubrication of all moving parts. Despite this, the nozzle still collides with the print in some areas.
Has anyone experienced something similar? What could be causing this? Any suggestions would be appreciated.
Thanks in advance.
I have the video but I couldn’t upload it.
Usually, this is caused by bad flow rate calibration. Too much flow will leave buildups on the print, and potentially build up on the nozzle until it’s grabbed by the print leaving a blob the nozzle hits when it comes around on the next layer.
Thanks for your reply.
I calibrate the flow before every print. Especially on larger parts, I can hear the nozzle rubbing against the part.
Do you have any suggestions?
This is more common than you might think. Especially if you use grid infill, or suffer warping that causes the print to lift off the bed a tiny amount.
Try:
  • Check for warping or poor bed adhesion, and find a way to fix those if they’re a problem.
  • Use a rectilinear or other infill pattern instead of grid.
The grid infill documentation says:
The grid infill consists of two sets of parallel lines intersecting perpendicularly, forming a crosshatch mesh. It is one of the simplest and fastest infill types.
However, the overlapping intersections can cause slight material buildup, and during high-speed printing, this may lead to nozzle scraping or abnormal noises due to collisions with the model.
There’s no problem with it adhesion. I’ll change the infill pattern and print again.
Hi,
I hope you can help a newbie with this topic and give me some tips. I have a similar problem. I recently bought a textured PEO plate. However, the nozzle hitting the print only affects the bottom layer. The one where the texture is visible is where you can see the scratches. On the opposite side, however, everything looks perfect. So the other layers must have been applied well. I’ve already printed at different quality levels, changed the height of the first layer, changed Z Hop, but nothing helps. What would you suggest I should try?
Try bed leveling the Textured side. The two sides will not have the same offset.
Usually it’s grid infill. Try another infill to see if the problem persists.
Changing the filling texture might help. I’ve observed a reduction in the problem.
Also, will doing this constantly damage the nozzle or head?
from a pure material perspective if your infill is at the recommended setting around 15% there shouldn’t be a problem with the nozzle itself though the real bottleneck is the filament pipe above the nozzle which isnt very thick and may be bent depending on how hard it hits and how long this is going on…
upd.: I tried recti, line, grid, gyroid, lightning (even there scraping…)
the only one that had ZERO scraping so far is gyroid (10%)
@R3d-Five
The plate can be used on both sides: Both sides have a smooth surface, which leaves a pattern (carbon or mesh). Can’t describe it better, but the offset should be the same.
@R3d-Five & @Ahmet_YILDIZ
I’ll try playing with the infill options - thank you very much for the tip!
In another thread those plates came up. They suck. Well in my humble opinion they suck. I thought you were talking about the dual sided BL plate, texture/smooth. My bad.
As the advice given there, you may want to start upping the temp on the plate by 5 degrees until you see some improvement. I wouldn’t go over 65 though. The can be the culprit with warping and you must keep them clean. I have 4 that I build a little house for all my regrets to live in.
I need to expand.
I’m currently trying some different infill options. I’ll increase the temp, too. I’ll let you know if I’ve made any improvements.
Success! I have changed the infill pattern and the bottom surface pattern to “hilbert curve”. I also increased the temperature to 65 °C. Although this pattern is somehow visible if you look closely, there are no longer any actual scratches left on the surface of the print. And the texture with the mesh comes across well. So this is a significant improvement for me. :slight_smile:
The downside, however, is that it tripled the printing time…
Try crosshatch if you need some more strength, but drop the infill lto about 3-4 less than you usually would. Gyroid is a favorite over grid, as is cubic. The times vary but looks like gyroid is the only one close to Hilbert. Gyroid would be better and stronger.
These of course depend on what it is you’re printing. I wouldn’t use Cubic on a small model. or low infill. I have become a fan of Cross Hatch over gyroid though. It’s a particularly strong infill and need less percentage to strength as the others in my opinion. Remember, in MY opinion, Play around with them on different size models and see for yourself.
To keep from seeing the infill increase the top layer count. Just do tests and add 1 layer at a time. Gyroid and Cross Hatch won’t need as many as say Cubic. Depending on model.
Good luck.
Which areas? Could you explain with more details? Depending on where the nozzle is colliding with the piece, there are different problems.
It started in the past months
The nozzle makes noise when it starts traveling.
It doesn’t matter whether it’s inner or outer
Gyroid seemed the only option so far where it didnt happen for me, I also struggle with that since I got the printer 1month ago, have you tried that?
all grid like infills caused issues, including even lightning…
Am I correct that the problem was not immediate? That it seemed to appear after use to become more and more pronounced?
If so, I’ve had the exact same experience to discover two culprits:
  1. Loose assembly screws throughout the machine. If you don’t already have them get a pair of “jeweler” type hex drivers with a swivel head. Read through various replacement instructions at the Bambu A1 wiki to essentially disassemble the entire machine to access as many fasteners as reasonably possible. Tighten the fasteners in related groups and then repeat to ensure that they are all snug. This certainly includes every screw in the printing bed and its platform!
  2. The other problem is uneven Z (vertical) movement that results in the X-axis becoming progressively out of parallel with the printing bed. This [seems] to start with a firm collision between the print head and a partly printed object of sufficient force to either knock the part off the plate or cause the machine to detect the collision, stop printing, move the print head to a “safe” location and display a message an error message with the possibility to resume printing. Once this occurs the problem seems to increase with continued “normal” operation with the misalignment eventually become very noticeable to the eye. While bed leveling and mechanical geometry of the process are intended and designed to properly deal with this exact situation problems seem to creep up as the misalignment increases. To correct follow the instructions for Z-axis belt replacement. This is not a difficult job. Provided the belt is in good condition there is no need to replace.
