Hi,
A1 mini can change the nozzle type to stainless or hardened in the maintance settings. Some websites mention that it is recommended to increase the print temperature when hardened, so I am not sure if this change will adjust all the necessary settings, or if I should increase the temperature of the hardened nozzle to achieve the same condition.
Changing the type of nozzle in the menu will not change the temperature but it will adjust the internal settings to maintain the temperature you set. I wouldn’t worry about adjusting your temperature between between nozzle types unless you find you are having issues related to incorrect temperature such as poor adhesion or stringing.
