I was running high accuracy nozzle offset calibration on h2d today. I have 0.6mm WC and 0.6mm Obsidian HF nozzles installed. I used black and white polymaker pla ht for the calibration. I get excessive extrusion. I did run full calibration cycle for flow rate as well. The actual print is OK, but there is clear oozing and over extrusion at start of print. If this was a real print, i’d have it all calibrated out with max flow and probably lower temperature and such. But I can’t change those things, for cal profile that is loaded in the printer itself. It seems like it is optimized for standard flow 0.4mm nozzle, not 0.6HF that i am using. Is there a way to adjust it for proper extrusion or does it not really matter since it is just XY offset calibration? Also, for some reason when i select polimaker PL:A in AMS config it sets max temp at 240 and does not let me drop it lower. I suspect i need 210 due to my 0.6mm HF nozzle.
